Hey, i'm a new forum "poster," but I've been reading this forum for a long time. I have a major problem with my Spider-Man PAL SVCD which is on 3 discs. When i play it on my Pioneer DV-434, the picture is smooshed from the top and bottom! The people in the video look really fat. I tried using the newest version of TMPGEnc to fix this by using the SVCDFilm template and then trying the 1:1 VGA feature, but it still wouldn't work! HELP!!!![]()
Maybe this PAL->NTSC process will help:
http://forum.vcdhelp.com/viewtopic.php?t=96892 -
Hey Binky, i tried the link u tried, and it said that i had to download a template for TMPGEnc, but when i try the link it says that the file is missing @ Geocities. Thanks for the reply, but do u or anyone else have any other ideas, or ideas with active links???
remove the ".zip" from the URL. Thus, use this link:Originally Posted by Apocalypse316
http://www.geocities.com/pinoy2201/pinoy2201svcdtemplate
or your browser may do better with the original URL:
http://www.geocities.com/pinoy2201/pinoy2201svcdtemplate.zip
It's a little wacky, sometimes you have to stick the ".zip" back at the end of the end of the URL. Hit Refresh in your browser for each try. Deleting your Cache files may be helpful??
This similar Spiderman post should be helpful:
Converting SVCD to VCD
> http://www.vcdhelp.com/forum/viewtopic.php?p=261722#261722
Specifically Stinky's May 18 08:59 Post
banjazzer's May 17 09:12 post (just above Stinky's) may also have some good info. -
Hey Binky!!! Thanks!!!! The template worked perfectly, thanks man! If u need any help, just ask me if u have any problems!!! :P
Poor man's 5.1
By Haopengyou in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th Nov 2010, 07:53 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 14:25 -
Spider Man 3
By rbaroncpd in forum DVD RippingReplies: 18Last Post: 14th Nov 2007, 10:03 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
