files not being supported
i think i have tried everything. iput dvd2 and plugin in all the smae folder and unchecked direct show. i am frustrated
I haven't tried 2.55, I use 2.52 mostly. & yes alk's question would help us help you. Have you installed the vfapi plugin. I don't think you should uncheck the Direct Show. See http://www.vcdhelp.com/tmpgenc.htm#problems for problems. Sorry I can't currently help more, but I'm at work now, maybe I'll have some time at home to lend more of a hand.
trying to open d2v and ac3 just as i have been doing. everything is there i have been using it for a while and then download 2.55 and everything went to h*** . does anyone know where i can get the olderversion?
check if exist in TMPGEnc Options- Environmental- VFAPI
the DVD2AVI Proyect File Reader.
or try download fron Tools section (at left)
the VFAPI Reader and convert (just in 3 seconds) the file d2v to avi
and try to open it.
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 12:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
