Is 640x480 a valid resolution for DVD video?
THX,JNT.
It depends on which DVD player you are playing it on. If you are converting from DVD to SVCD the the 'standard' is 480x576 and VCD (mpeg1) is 352x288) this may seem low res, but plays better than VHS.
My DVD player will play anything I put in it. Let me know more detail what you are trying to do and I may be able to help. I don't know anything about DVD writers though. -
Thanks for the reply.
I have the new Pioneer dv-353 and it can play anything. My winnov card will capture my home video at 640x480 @ 30 fps. I just want to know that if I burn the video at his resolution onto a DVD-R, it could be played by an other DVD player. (That can play DVD-R at least.) -
when you use spruceup to author dvd, you can do that
just patch the video part ahead in an resolutiom an aothor proggie
will accept like 720 x 576 (pal) or whatever when importing the
video part with the dvd patcher.
you can read about that here, its for svcd in dvdr format, but works
the same
http://www.vcdhelp.com/svcddvdr.htm
i also tryed it and works nice with spruceup
good luck
640x480 14,9fps video from mobile to 25/30 fps posible?
By mammo1789 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 17th Mar 2012, 07:06 -
Doubling the size of a WMV video? (320x240 > 640x480)
By kingmustard123 in forum EditingReplies: 26Last Post: 9th Aug 2011, 07:32 -
How to put 640x480 video in 1280x720 frame in Sony Vegas Movie Studio?
By vid83 in forum EditingReplies: 6Last Post: 10th Feb 2011, 23:47 -
i want to save HD video with 640x480 AND VERY GOOD QUALITY...HOW??
By khalid81 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jun 2009, 01:40 -
VHS to DVD resize 640x480 or 720x480
By opti280 in forum Authoring (DVD)Replies: 2Last Post: 26th Feb 2008, 19:43
