I've just acquired 3 Sun monitors from work as the old CAD system was being scrapped. They are 20d20's. I bought a Sun to PC cable adapter from Lindy and tried one out.
I know that they work as I've tested them on a Sun IPX.
When connected to the PC I get three overlaid screens in vertical bands one third spacing across the monitor. I'm running the PC with a Radeon 8500.
Is this a h/v sync problem?
Can these monitors be used on PC's?
Thanks in advance
"It's better to burn owt than to fade away."
Yorkshire Ripper -
You need to adjust you display properties, and video sync rate, something very low at 640X480 they would use a VGA driver for the display card not a SVGA drive which you have installed at the moment.
Sun Microsystems talks about "patent bullies"
By deadrats in forum Off topicReplies: 0Last Post: 10th Mar 2010, 22:27 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 09:28 -
Monitors, 16:10 or 16:9 which one should I get?
By gll99 in forum ComputerReplies: 11Last Post: 15th Jan 2009, 08:56 -
Sun xVM VirtualBox: Need advice on upgrading to new version
By FulciLives in forum LinuxReplies: 3Last Post: 22nd Sep 2008, 07:05 -
Are monitors HD?
By Nitro89 in forum ComputerReplies: 11Last Post: 28th Apr 2008, 18:59
