I recently downloaded some AVI movies. I'm trying to convert them to sVCD format using Tmpgenc, but the audio didnt convert.. so the result of the mpeg has no audio sound. Now, I dont have a problem with the AVI audio playing it on my computer.... please help!
Here's the info that was provided with the AVI Movie.
Encoding: Divx4 & 320k VDR MP3
Thanks,
sky
Baldrick the Webmaster helped me with a similar problem,
he told me to use virtualdub to extract the audio as a seperate file
and then use tmpengc to convert. You will need to save the audio
as uncompressed, I can't remember the settings offhand.
The link he gave me was
www.vcdhelp.com/virtualdubaudio.htm
Cheers for now. -
I forgot to say why you need to save the WAV as uncompressed,
if you don't the sound goes out of synchronisation. This is because
the sound is saved as VBR (variable bit rate) which doesn't convert well. -
thanks for the info. I've try what you asked me to do. and it work. but now i am having a weird problem. in my avi movie, the audio doesnt come in until.... about 8 seconds later... well, because of that my audio time and the AVI time is off. that means I would have to cut the beginning of the movie. thats hard to sync the audio with the movie... any suggestions???
If you have got Adobe Premiere, import the file, then drag it onto the timeline, right click on the video track and unlock the video and audio.
Then move the audio track backwards or forwards, play the preview and when you have got it synched, save it.
avi audio sync problem.
By Corpsecreate in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2011, 12:06 -
AVI audio sync problem
By zakowako in forum Newbie / General discussionsReplies: 0Last Post: 19th Oct 2010, 12:35 -
extract avi audio problem
By gibkho in forum AudioReplies: 8Last Post: 13th Jun 2010, 13:18 -
Avi to Divx audio problem
By win993 in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 17:53 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
