  1. I found a really simple guide to convert DV to Mpeg2 in Premiere 6 using link to AVsynth plugin, and frameserving to a stand alone encoder such as tmpgenc or LSX.
    But I was also told by someone that Frameserving wont work in Windows XP. Is this true? does anyone have any experience with this? please let me know - thankyou
    Ok - you got me - i dont know anything - you happy now!
  2. Works fine for me. I use XP and frameserve from premiere to tmpgenc.
    Mickle
  3. I frameserve from Vdub to TMPGEnc all the time in XP (home edition)
  4. Ok - I can get Premiere to start frameserving using Link to AVIsynth - but I cant get Tmpgenc to accept the frameserver - I have followed the instructions but Tmpgenc wont recognize AVS files even after I installed the AVS import filter. Some one please help
  5. Its really weird too - In tmpgenc when i try and open a file it allows me to choose the AVS and VDR file extensions to open but when i try and open the AVS file extension it says its unsupported - it makes no sense to me.
    Feb 2001
    Berlin, Germany
    TMPG > option > enviromental setting > vfapi plugin > disable direct show multimedia file reader.
  7. i use XP and have no problems using DVD2AVI -> tmpgenc for conversion.
