Hi everybody!
If I create a vcd or svcd cd with the help off TMPGenc and NERO, everything looks good on my Philips DVD957. Though, if the material is too big for one cd, I of course have to cut it. Once again I rely on TMPGenc to split the mpg. After burning it again with NERO, I can not play it on the DVD! The DVD identifies the vcd as a regular audio cd with 2 tracks on it. What could be the reason?
To clarify myself, if I compile a 500MB mpeg1 vcd file and burn it, it works 100%, but if the file is, lets say 1.2GB and I split it, it does not work.
Appreciate any help on this
Chris Wahlin
Critical Graphics @ www.cgfx.nu
3D Graphics artist from Sweden
cw@cgfx.nu
Are you sure that when you use the cut/merge facility in TMPGEnc, that you use the correct pull-down stream type?
Cutting MTS: splitter problem
By cheerful in forum EditingReplies: 3Last Post: 6th Jun 2012, 20:26 -
subtitle problem after cutting commercial from video
By satish_j in forum SubtitleReplies: 4Last Post: 25th Nov 2010, 01:51 -
Little problem-Cutting Scenes-Ideas?
By n3ur0 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 09:44 -
[FR] Cutting TS Help Me Please
By KERNEL32 in forum EditingReplies: 5Last Post: 26th Feb 2010, 14:38 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 07:53
