Microsoft have released a final driver for USB 2.0 - June 11th 2002.
"Over the past two years, Microsoft has been working with industry partners on the USB 2.0 project. We are pleased to announce that USB 2.0 drivers are available for Microsoft® Windows® XP through Windows Update . USB 2.0 driver support for Windows 2000 , is also now available. The driver version 5.1.2600.0"
http://www.microsoft.com/hwdev/bus/USB/default.asp
FAQ:
USB 2.0 runs at a whopping 480 Mbits/sec (or 60MBytes /sec) and features complete backward compatibility with the original USB. At the present time USB 2.0 will most likely not completely replace its predicator because, simply, a keyboard or mouse doesn’t need 480 Mbps bandwidth. Most likely all newer PC to come will come pre-packaged with USB 2.0 support. While peripherals won’t utilize 2.0, it will be great for web cams, digital cameras, etc.
USB 1.0 crawls at 12 Mbits/sec (or 1.5 MBytes/sec)
You need a USB 2.0 PCI card if you dont have it built into your motherboard (very few do). Belkin do one for about £40. You also need USB 2.0 peripherals, usb 1.0 peripherals will work with a usb 2.0 card but only at the speed of usb 1.0
Craig -
These are peripheralsWhile peripherals won’t utilize 2.0, it will be great for web cams, digital cameras, etc.
Craig -
Most of the new motherboards have USB 2.0 on their south bridge chips.
All 845G and 845GL motherboards have built-in USB 2.0. Some of 850E have USB 2.0 but they are more expensive. Some 845GL motherboards are under $90 with built-in graphics, too.
Most of VIA and SiS chipsets have USB 2.0 as well. Some of them also have IEEE 1394a and in the second half, some SiS and VIA motherboards will add Serial ATA, 802.11, Home PNA 2.0, IEEE 1394b and so on.
ALi, ATi, and NVidia also either have released or announced to release USB 2.0-supporting motherboard chipsets.
Looking for driver for Belkin Hi-Speed USB 2.0 DVD Creator
By Cazz in forum Capturing and VCRReplies: 2Last Post: 6th Mar 2010, 15:06 -
Microsoft Security Essentials anti-virus now FINAL and free.
By roma_turok in forum ComputerReplies: 3Last Post: 29th Sep 2009, 17:31 -
ReQ: Visioneer 4800 USB Scanner Driver
By Teac23 in forum ComputerReplies: 7Last Post: 14th Jan 2009, 10:02 -
Help install my USB PCI card Windows 98SE,have driver can't find hardware
By bnbhoha in forum ComputerReplies: 6Last Post: 13th Feb 2008, 13:58 -
Help with USB driver for Panasonic PV-GS120 miniDV
By bowmah in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jan 2008, 16:31
