  1. Hi there. was wondering what I'm doing wrong here... I've followed all the steps so far in "Sefy's Classical Guide to DVD ripping into VCD's". But I'm stuck at the TMPGEnc step. It won't support my .d2v files. Last time I looked, I did have the VFAPI and the DVD2AVI.VFP files located in the same folder as the TMPGEnc.exe is, so I just don't know what I'm doing wrong here. I do believe I'm running the latest versions of all the software.
    Please help.
    Atlantic Beach, Fl
    You might need to install the [url-http://www.vcdhelp.com/download/m2v_vfp-0.4.6.zip]MPEG2 Plugin[/url] for TMPGEnc...
    Big_Jit
  3. I suggest you re-download: TMPGenc / VFP Plugin / DVD2AVI
    Delete your TMPGEnc folder, unzip all 3 files into the same folder, then run the Batch file that comes with the VFP plugin.
    Then use the newly unpacked DVD2AVI and re-create the D2V/WAV files from your VOB files.
    Then try to open the D2V again, and report back.
    Please do EXACTLY like i've said, don't skip a step.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
