I have been making vcds/svcds on my mac for a long time. Whenever I had sync problems I would either go to QT mutator or FCP. But what I am trying to do now is skip some steps to cut time. I have ripped a dvd's mpeg2 and ac3, took the mpeg2 to media pipe to go strait to vcd complaint video and took the ac3 and coverted it to a 44.1k mp2. Basicly it is ready to be burned other than syncing the audio and splitting the mpeg in half. I can't give it to the mutator because it uses quicktime and you can't edit mpeg in quicktime. And to the best of my knowing FCP1 does not support Mpeg editing either. Anyone have any ideas because I was able to get almost two and a half hours of mpeg2 and ac3 to vcd in 5 hours.
P.S. I already have a program that will spit mpegs on the mac. Oh and no Virtual pc if possible but I am open to options.
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
AC3 and mpeg1 audio
By izzykatz in forum Newbie / General discussionsReplies: 6Last Post: 14th Feb 2009, 12:39 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 20:00 -
MPEG1 SYNC error
By diginode in forum Authoring (DVD)Replies: 10Last Post: 2nd Aug 2007, 00:09
