  1. I looked for the proper forum, and hopefully this is the closest. I have dowbloaded a PAL version of Spiderman (Didn't know it till it was done. Is there any way to convert it to NTSC (Tmpgenc, or other?) or anyway to make a NTSC copy from PAL?
  2. Yep, you can use the TMPGEnc and select a NTSC template and convert, I recommend using VCD-NTSC Film. My Player has always been picky with SVCDs I converted from pal to ntsc vcd, but not VCDs. If it is a PAL SVCD, pal VCD is worth a try, my player plays PAL VCD but not SVCD.
  3. I tried that. I get audio but, still no video.
