i am having problems with tmpgenc reconizing m2v file is anyone having this problem?
Results 1 to 11 of 11
hi...had the same problem....first...increase the priority of dvd2avi reader in tmpge....then...save ur avi's in the same place u save ur encoded file...check tmpge site for the latest plug ins.....good luck!
this is an actual dvd rip from dvd2avi and there are no updates for tmpgenc
not reconizing d2v or ac3 audio it says not supported can someone help?
Try unchecking the Direct SHow Multimedia File Reader
in TMPGEnc
Options -> Environmental Setting -> VFAPI PlugIn -
<=== Download and Install the VFAPI Reader from Tools section
Convert the file.d2v to file.avi just take 3 seconds to convert it
try to load the AVI. -
8) I had the same problem. one project it would open fine and the next i couldnt open it at all. i found out it was b cuz i renamed the folder the m2v file was in. that will also happen if you move it to a different folder.
so just keep the m2v in the same folder and directory. let me know if that worked for you. oh if you changed the name of the folder be sure to change it back to the exact same name and spelling of the original name.D.J.
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
Programs won't reconize video file ?!
By Beastly Swagger in forum Video ConversionReplies: 1Last Post: 26th Jan 2009, 17:42 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
ffmpeg doesn't reconize sound in video file.........
By ssj2_goha in forum Video ConversionReplies: 15Last Post: 18th May 2007, 15:38
