Is there a way to identify what codec was used to compress a file if you don't know? I'm using xp Thanks
SteveK
Open in virtualdub. Get File Information will usually tell. If the audio is unknown 2000 or similar it is probably AC3
Panasonic DMR-ES45VS, keep those discs a burnin' -
I use a hex editor. Generally the codec info is somewhere in the first several hundred bytes.
I'm not sure Vdub can identify a codec unless its installed already and a codec that Vdub can actually use (there are a few that aren't compatible - notably ASF, by design).
Good luck -
Thanks for the replies. I am quite new at all of this and have much to learn. Mbellot, I do use virtual dub and it does have a hex editor in it. Now, I opened a file with the editor and had no clear concept of what I was looking at. I used the edit tab and did a search for "codec" of course, I didn't find anything. Will the editor actually name the codec being used, or do I have to know how to read something cryptic? Thanks again.
SteveK -
Steve:
Not really, you just have to poke around in the first several hundred bytes. If its an AVI (most other file formats are pretty self explanatory - MPG, MOV, RM, etc) then you will *typically* see something like "vidsdivx" or "vidsIV50" near the top of the file.
Obviously, the first example is DIVX. I believe the second is Intel Indeo V5.0... You may also find more info further down, like in DIVX 5.0 files. Shortly after the "vidsdivx" you will see "DX50".
Once you have identified the codec (or more likely the abbreviation the mfr used) its time to hit Google and see what you can see. If you don't get much from the web search try the newsgroups, they can sometimes be a great source of off the wall info.
I've never used the Vdub hex editor, so some (or all) of the above info may be completely worthless until you get a "real" hex editor. Check around, there are several good freeware editors.
Also, a little hacking (not the bad kind) knowledge would be very helpful, but that is usually only gotten the hard way.
Help Identifying Source
By Charolastra in forum DVD RippingReplies: 8Last Post: 14th Apr 2012, 04:19 -
Can you please help identifying this file ?
By fa355115 in forum Video ConversionReplies: 1Last Post: 23rd Jan 2012, 09:27 -
identifying codec.......
By nodollas in forum Video ConversionReplies: 16Last Post: 30th Sep 2011, 13:48 -
Identifying OS on DVR HD
By juststarting in forum ComputerReplies: 6Last Post: 24th Feb 2010, 01:29 -
Help identifying drive
By thekfc in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Jan 2008, 09:28
