Can anyone tell me if Premiere 6.0 supports AVI's captured through the Dazzle Hollywood Bridge from analog sources. I used the Dazzle Digital Creator which only produces MPG 1 for about a year 'till it broke after trying to capture directly into Premiere. Then everything got wierd and the device stopped being recognized even by Dazzle's software "Moviestar". Don't know if that is what broke the device. Anyhow, I want to try the Hollywood Bridge because I'm capturing from commercial VHS movies and DVDs for a project and I know Dazzle products to not recognize copy protection. (The Dazzle Creator captured flawlessly from commercial movies and DVDs) It doesn"t matter if the Hollywood Bridge can't capture directly into Premiere as long as I can import the AVI's and edit them. By the way, I did convert some of my Mpgs to AVIs with Virtual dub, but the quality degraded abit--that is why I want to capture to AVIs. I use a PIII 800MHz with 512mb Ram and a dedicated 60gb hard drive. Any comments, tips or suggestions appreciated. Thx in advance.
You might get an answer on this DAZZLE forum, Jarrah.
http://www.long-distance-longdistance.com/phpBB/viewforum.php?forum=1&8378 -
I used the Hollywood Bridge about a year ago to capture DV from Hi8 and edited with Premiere. It worked fine. My Bridge unit was not reliable so I returned it, but there were no compatibility problems. I believe I captured using the software that came with the bridge.
Just keep in mind that Premiere expects a Type-2 DV file so if there is any option for Type-1 or Type-2, make sure to select Type-2.
Ivy Bridge to be up to 199% faster than Sandy Bridge
By deadrats in forum ComputerReplies: 33Last Post: 7th Dec 2011, 13:06 -
it may be smart of hold off on sandy bridge...
By deadrats in forum ComputerReplies: 2Last Post: 12th Feb 2011, 23:04 -
New Intel Sandy Bridge cpu
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2011, 08:19 -
Dazzle Hollywood DV Grounding Fix
By mk2000 in forum Capturing and VCRReplies: 6Last Post: 15th Apr 2009, 09:20 -
Adobe Bridge m2t files
By vegasarian in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2008, 10:39
