ok...i'm sure this question has been answerd several times already but...i can't seem to fin d the answer....
to encode to svcd..(480x480) does the source need to be 480x480 ..?
i have an divx witch is 640x272...can i convert this to a svcd without a great loss of quality?
i tried to convert it with TMPGEnc to a vcd and when saw it on my dvd it was fullscreen and perfect quality...why?
i can't figure it out....?
i need some help on this one....
thanx
No your source doesn't have to be 480x480 or larger but it would be better if it was. Its not a good idea to raise the resolution if possible. The result is that the picture gets very blurry and any artifacts already present in the video will get much larger as well.
Samsung CRT sp43t7hlx/shi - Resolution problems in w7
By runkz in forum ComputerReplies: 1Last Post: 27th Nov 2009, 02:31 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
sorenson squeeze resolution and fps problems
By phpmysql348 in forum Video ConversionReplies: 7Last Post: 7th Sep 2008, 22:46 -
Resolution problems when converting with FUW
By Malicious in forum DVD RippingReplies: 1Last Post: 8th Aug 2008, 01:02 -
DVD resolution problems / confusion
By Laurels in forum MacReplies: 2Last Post: 5th Jun 2008, 03:57
