Okay I've tried all the researching I can but I can't find out what's wrong with my card.
I have an older PC, but it still works well:
Gateway Windows 98SE
Pentium III 733
7200 20GB HD 11 GB free
128MB SDRAM
I don't know how the exact model of my WinTV card, but its as old as my computer and the driver is from Hauppauge in 2000...it skips a lot when I record video with the Hauppauge application
1. I treid Hauppauge's new VFW drivers and there was no skipping at all, but they gave my really bad horozontial lines
2. I found out my old driver was wdm so I tried their new wdm driver...and capturing didn't work...
3. So I tried VirtualDub with my original driver and it worked perfectly BUT it only worked once and now when I got to File>Capture AVI my entire system freezes!
If Someone has had the same problem with VirtualDub or knows what the problem is, please hlpe me.
BTW- I'm capturing a concert I taped on a 8mm camera with S-video input. For capping I'm using HuffYUV codec and capping 352x240, 29.97fps, mono 16-bit sound....
Thanks if you can offer any help
-Rob
Try this http://www.hauppauge.de/nanodvr.htm
I use it with a WinTV2000 to capture to Mpeg1 files, works very well. Other than that WINTV2K and capture to DivX
Your WinTV2000 card has some softwear to tell you what card you have "prodinfo.exe" installed in the folder.
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 04:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 07:00 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
