  1. I did everything right up 2 having a part0.avs. (If u dont know what Im talking about check out http://www.vcdhelp.com/dvdtovcdflask.htm & go 2 the bottom.)
    The only problem is I can't play it with windows Media Player & can't covert it using TMPGEnc 12a. TMPGEnc says when I try 2 open it: "The File "C:\part0.avs" cannot be opened or it is unsupported. Any thoughts on how 2 fix this?
  2. Can anyone help?
    Feb 2001
    Berlin, Germany
    try a different thing.
    Open notepad, type
    IPCSource("flaskout0")
    save as flaskout.avs to any directory.
    (recall, flaskout.avs not flaskout.avs.txt)
    To see, whether it is correct, open flaskout.avs with mediaplayer, close.
    Open TMPG, select flaskout.avs as videosource.
    <font size=-1>[ This Message was edited by: Truman on 2001-08-09 06:40:55 ]</font>
