When I have made a movie in Pinnacle (*.sdv) and try to render to MPEG (vcd), it stops after a while and it locks the program. If I try it again later, the same problem after the same amount of time. When I take another (*.sdv) movie it finishes (even if it's longer).
There is enough memory and disk space.
Use Pinnacle Studio DV. Trouble with converting the *.sdv file to MPGEG (vcd).
I have had the same problem and I quit jumping through their tech support hoops. If you output to a high quality AVI (like Indeo 5, 100% quality) then feed that into TMPGenc you'll probably get better quality and it will not get stuck.
Hope this helps! Da KittyPanasonic DMR-ES45VS, keep those discs a burnin'
Having trouble with my Pinnacle Studio 11
By pietra4521 in forum Capturing and VCRReplies: 3Last Post: 6th Jul 2008, 15:16 -
Pinnacle Studio 8
By Victri in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2007, 04:18 -
Pinnacle Studio 11
By fjmr in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 03:44 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
Is anyone using Pinnacle Studio 11 ???
By maxtrack in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 22:56
