    Apr 2002
    Florida
    ok followed the guides on doom. i'm making a dvd-r copy of remember the titans. i ripped it fine. threw it in infoedit and took out the french audio, the subtitles i don't need and the extra english audio. i'm around 5.5GB right now. now i need to re-encode and i'm not sure exactly how to use dvd2avi. i have looked for guide and didn't find any that were for creating a d2v file needed to put into tmpeg. i went to save project and i thought that might be right, but i'm also unsure if i needed to do anything with the setting or not. ok, well i got a d2v file, not sure if it was right or not. let's move along saying that i have the correct d2v. i fire up tmpeg and from there i set it up just like it says in dooms guide. i try to load the template from infoedit and it locks up permanently, and trust me i'm assuming after 2 hours that it wasn't coming back to life. so i'm not even posotive if i made the template right or not. i'm extremely grateful for the guides, but there is a lot missing in everyone i have seen. missing steps, assumption that i am going to know certain things. well i feel like a retard here because i don't. in any case i'm seriously stressing over this, and i'm assuming i can get along on other disc's fine if i can figure out the problems i'm having with this one. well thank you in advance to anyone that can help me out here.
  2. Post your PC specs, settings used in TMPGEnc, VBR? , CBR, was invert telecine enabled?
    Apr 2002
    Florida
    amd xp 2100+ 1GB RAM, (2) 120GB western digital 8MB Buffer striped, xp pro. all of my tmpeg settings were just as they were laid out in the doom here http://www.doom9.org/mpg/tmpg-dvdencoding.htm i never got past the step where i loaded the infoedit template, it froze there. i also tried using rempeg but it wouldn't even start the re-encode. could i or should i use cce to re-encode it, would that be better, sounds like it makes better copies. if i use that though how do i get the files in and then back out to the original vob's? i haven't ever used cce
    Apr 2002
    Florida
    ok, well not sure where this falls in the realm of i screwed up royally, but i got cce to reduce the video down, but when i remux with infoedit the sound is way off. damn i wish there was a detailed step by step guide for this. also if anyone has done a dvd-dvd-r for remember the titans then please God let me know what you did =)
