Will it drop many frames, I have
VIA Cyrix III
Windows 98 SE
318MB Ram
600 mhz
Will this do the job, I want to captuer at 352 x 288
My experience says that much depends on which program you use for capturing.
I have an "older" system by today's standards - Pentium III/500 with 7200 HDD and 384 MB SDRAM and an AverTV PCI card. I capture 484x484.
I used to use VirtualDub, but get audio sync problems and dropped frames.
With the *exact* same compression codec, capture size (484x484), PicVideo MJPEG codec @19, etc in AVI_IO, I get either 0 or 1 dropped frame(s) in a 30 minute TV capture and no sync problems!
Let's not even talk about how many frames the AverTV's own capture program drops or it's capture quality... -
You'll probably be fine... I've captured 352x480 with one on a
400Mhz machine and very minimal / insignificant frame drops. -
I've been happy with mine. The only time I tend to drop a worrying amount of frames is from an unstable video source. If you have a good clean signal feeding into the card you should be fine with your setup.
Nick -
WinTV is much much better than ATI TV wonder VE - Trust me I have experience with this. I like it so far - you will drop frames if you capture 680x480 - how depends on the proggy your using - but if your just interested in making VCD's than 320x240 should do you just fine. i capture that using whatever codec i want on a 900mhz and I dont drop any frames at all - so i wouldn't worry. If you want higher res than that with no dropped frames your gonna have to pay for it - and you aint gonna pay 50 bucks let me tell you
Ok - you got me - i dont know anything - you happy now!
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Good HDMI or Component Capture Card for Game Consoles?
By jargus in forum Capturing and VCRReplies: 18Last Post: 26th Jan 2011, 11:37 -
Once again - Good capture card for beginner
By MillowQc in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2009, 23:14 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 18:02 -
Good Card for Video Game capture
By npsken in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2007, 08:55
