I haven't had any problems remuxing the ac3 audio back into my video but when I play it back on my standalone it is not as loud as on the original DVD. I use the ac3 file created with DVD2AVI it creates a d2v file to use with CCE. When I am done encoding my video I use Spruce up to remux the audio and video. Everything comes out fine but I noticed that I have to turn the volume to the max to hear it. Is anyone else having this problem and is there another to remux the ac3 audio with the same quality as the original DVD? Thanks in advance.
try using smartripper to rip your video and audio. YOull get an m2v file and an ac3 file which you can import into spruce up. I have had no problems with the audio level doing it this way. Hope this helps.
Amateur Question: My DVD9 doesn't support AC3 Audio
By Keziapurrs in forum AudioReplies: 15Last Post: 10th Jul 2011, 20:03 -
Question about audio when ripping DVD to AVI file
By joylamyy in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2011, 15:56 -
Ripping a Track Out of an AC3 File?
By SLK001 in forum AudioReplies: 0Last Post: 18th Mar 2011, 01:10 -
AC3 Audio Question
By Rimmer209 in forum Video ConversionReplies: 1Last Post: 24th Aug 2010, 20:24 -
Question about hd audio in wmv hd - is it ac3/dts compatible?
By yoda313 in forum Blu-ray RippingReplies: 4Last Post: 12th Mar 2009, 17:12
