  1. Member Gargoyle's Avatar
    Jul 2001
    Southern New Jersey, USA
    Thinking of buying a AIW 7500 - Anyone know if there is any difference/improvement in the capture quality compared to the AIW128?
    Any other thoughts or opinions?
  2. There is NO DIfference other than the MMC7.6 software (which will work with the AIW128 / 128 PRO). Both cards use the same Tuner / Capture chips. Difference is in the PC Graphics chip only.
    MMC7.6 Does a better job at capture BTW.
    I have an AIW 128 PRO and am using MMC7.6 now - works great. Like the seemless capture which automatically breaks up capture into smaller files and you can set the file size to anything you want.
    Rob
  3. Ratt794:
    I see you are using MMC 7.6 - did you also install the updated capture drivers? If so I was wondering if you stopped being able to capture audio in VirtualDub.
    Ignore this question if you don't use VirtualDub.
    Regards,
    Drak
  4. As far as I know the capture drivers are part of MMC7.6. I am still using the video driver for the PC part of the card as before. MMC runs the Tuner / Capture part of the card.
    I don't use virtual dub - tried it one and did not like it.
    Rob
  5. i am still using 7.1 and seems ok with me, but i wonder if it's worth upgrading....
    can you tell me why 7.1 is better than 7.6?
  6. Well you know the old saw - if its not broke...
    However, if I were only using MMC then I would upgrade to 7.6 as I've heard several people comment that it captures better then 7.5. If you download it from ATI's web site the capture drivers are a separate download and install (which I did). But I am concerned that the new version restored an incompatibility with my preferred capture software, unfortunately I have not had time to test (I sometimes have to work on projects that actually generate income).
    Drak
