i have gota samsung dvd 511 it says on the front it can play vcd's however i have been unable to get it to play any as the screen says it can not play this disc. i have set it up via the handset to be multi region all the time, has any one got any ideas, please help. also does any one know how to make it play cd-r's? thanks
so what you are saying is that if somebody copies a film in vcd format to a cd rw it will work? I have tried it on cd-r but have had no luck. Are cd rw more expensive to buy?
CD-RW should work. I used to have this player and use TDK CD-RW's with few problems. They are more expensive than CD-R's but at todays media prices it shouldn't be a problem, esp if you shop around.
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45 -
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 10:34 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 23:06 -
LG LDA 511 turns off in the middle of a movie!
By Wantonmaya in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Oct 2008, 17:56 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42
