  1. ive ripped a dvd into an svcd and burned it
    but when i played it, the picture jitters non stop like a copmuter game does if your pc is too slow
    i know its not the dvd player because i dowloaded
    the sample svcd from this site and copied it and it worked fine
    PLEASE HELP ME!
    i followed the tutorial on how to do this and everything
    was done according to the instructions
    <font size=-1>[ This Message was edited by: ZxTHUGSTAxZ on 2001-08-04 03:45:53 ]</font>
  2. this is what i used to rip the dvd
    Tools you need: SmartRipper 2.25 / DVD2AVI 1.76 / TMPGEnc 12e /
  3. doesnt anyone know what to do?
  4. Quote From Sunmiztres
    If it is jerky you probably have your field order backwards. Encode it again using the opposite field order you used the first time. Upper field or lower field under the advanced page on tmpgenc. You have a 50% chance of getting it right so i would encode a small part to see if it is the right field order before encoding the whole video. Hope this helps.
    This worked for me, hopefully this will solve your problem.
    Good Luck!
  5. ok ill try that
    thanx!
