  1. I know this has been asked and answered everywhere, yet i`m still having trouble. Its PAL region2 and has multiple angles, if i remember correctly it has around 5 or 6 PGC`s that are the same length. Ive tried smartripper to rip just 1 angle and when i play the vobs back to check , it gets about 2 minutes into it where the bird beats that cop up and does the fancy slowmo kick, that part stutters like hell, like it missing parts (probably is i know), ive tried ripping the other PGC`s, same still. Ive tried DVD Decrypter and ripped ALL the files to HD then used IFOEDIT to remove the seamless branching and keep just 1 angle, same happens, i use dvd decrypter to rip and remove the angles and same thing happens again. Anyone know what the hell i need to do ? Its driving me crazy.
    May 2001
    Use Smartripper to rip ALL of the movie, then use IFOEdit to remove seamless branching. The part where Trinity does the slo-mo kick of the cop uses a part that is off movie. The method above will fix that.
  3. Coincidentally i just ripped with SR stream processing just the movie-m2v and english ac3, was going to just author back as its ok, but wud rather have kept the movie menu + extras intact, so i`ll try your way. Just use SR and rip all the files in FILE mode?
    thanks (if it works) hhehe
  4. i did it the simple way - i just downloaded the whole movie on 3 svcds. took less time to download it than it would have taken to rip it too.
