Now that I have captured the clips from my DV, edit it and added transition events to it, I thought I have finished with my video file and ready to burn it to VCD. However, when I played the file, I found that there are many noises. Moreover more important is that my voice is always very loud, because I was the camera man and thus closest to the microphone of my DV camcorder. But the voices of those I focus on (e.g. my wife, my friends, etc.) are very low, because they are comparatively far away from the microphone.
Is there a way for me to make all the voices to be in similar loudness? Is there any freeware tools for this? Also I wonder whether there are any tools which can also help to remove the background noices from my video?
Thanks a lot in advance for your help.
Regards,
- David
these noises are probably the interlace fields in the DV file. when converting to a non interlace file, use the interlface filter in your encoding program,i use tmpgenc to do this. also, you can get an external plugin to normalize (even out the highs and lows) before you create the vcd. i'm pretty sure toolame does this with certain variables in tmpgenc. i saw the option last night but havn't tried it.
Grab yourself an external microphone for your camera for the next time.
internal mic's can pick up internal camera activities.
most camera's can accept multiple audio sources, one on your hotshoe attachment for distance work and another mic as a lapel mic for yourself using the audio in ports. Even better if you don't want yourself on the footage.
As for this time, you might be able to extract the audio out and modify if somewhat with something like Cooledit or SoundForge (cooledit should have a trial period) but I don't know of any freeware tools that will give you the precise control of just increasing volume of certain freqency's you need to.
Cooledit 2000 - http://www.syntrillium.com - demo available
Soundforge - http://www.sonicfoundry.com - demo available
Good luck with this - this is will be very difficult to complete -
With cooledit you can use the dyn-compressor feature:increasing low volume and decreasing loud voices.Thus reducing the dynamic, but the end result will be much better understandable.Use the noise filter for reducing the background noice.
You shouldn't use normalize before dynamic compression.
How to remove noise from my HD video
By ITW in forum RestorationReplies: 18Last Post: 26th Jan 2011, 12:24 -
How to remove different voices?
By nharikrishna in forum AudioReplies: 6Last Post: 28th Oct 2010, 11:19 -
Cleaning Up/Remove video noise
By Soixante in forum Video ConversionReplies: 5Last Post: 5th Apr 2010, 18:34 -
Remove Voices And Background Music From A Video
By DigitalDummy24 in forum AudioReplies: 5Last Post: 6th Mar 2010, 01:07 -
How to remove noise in audio of mkv file
By maass in forum AudioReplies: 1Last Post: 11th Nov 2008, 03:08
