I try to make .mpeg file with permanent subtitles, so i have to use VDub 1.4.10 as a frameserver. I make the following actions:
- Install Handler from AuxSetup.exe
- proxyon.reg from "aviproxy" directory
- when starting frameserver i save file with .avi extension.
But TMPGEnc refuses to open this file giving error "...avi can not open, or unsupported".
Can anyone please advise me what must be done to make VDub to be correct frameserver?
Hi There !!!!
I have had the same problem, but I solve it using Virtuel Dub ver. 1.4.9.
So uninstall ver. 1.4.10 and try again, bet it works !!!!! -
I would consider using AVIsynth because it's faster. look under the subtitles guide by Truman:Originally Posted by serg666
http://forum.vcdhelp.com/viewtopic.php?t=87065what are you askin' me for...
I'm an idiot!
AVI to DV fails after one.
By bmccall17 in forum ffmpegX general discussionReplies: 3Last Post: 15th Jun 2009, 12:49 -
mencoder fails
By scruss1 in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 23:48 -
burns fails. help
By dymx in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2008, 14:54 -
Burning always fails at 98%...
By Variable in forum DVD & Blu-ray WritersReplies: 14Last Post: 29th Feb 2008, 16:45 -
VirtualDub 1.7.7 fails?????
By Gritz in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2008, 10:05
