Hi, i have a problem, when i shall open an MPEG file in VirtualDub iget the message "MPEG Import Filter: Unexpected end of file". Yes i know, it,s not the whole movie. Could i fix the MPEG file anyway?
Thanks.
Yes, in menu "File" -> "Open video file" you must check the option "Pop up extended open options" and after check "Accept partial streams".
MPEG-4 frame skip problem - any way to fix it?
By TMHKR in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 08:42 -
MPEG-4 into vid editing software looks like shit, how can i fix?
By davidkim in forum EditingReplies: 1Last Post: 8th Dec 2008, 22:44 -
How to fix MPEG encoded with wrong aspect ratio?
By Talayero in forum Video ConversionReplies: 2Last Post: 21st Oct 2008, 10:29 -
MPEG File Size and Runtime differ greatly. How to fix it!?
By prophecy202 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jun 2008, 23:37 -
MPEG from HDTV2DVD has low volume how to fix please?
By ChrisU2Edge in forum DVB / IPTVReplies: 2Last Post: 17th Aug 2007, 15:28
