is it poss to get 5.1 sound on vcd or svcd
i have player with 5.1 channels but vcds only work on front speakers
is ther away around this
many thanks
Doug
Hi,
I read that you can encode it - but no commercial DVD player will read it from a VCD or SVCD - so pretty pointless I guess.
Depending on your tv or av setup - you can get Dolby Digital Pro Logic - ie left,right,centre and mono rear channel which still sounds excellent...
I hope this helps...
TeeeRex -
There is no way to get 5.1 signals in a vcd. Svcd supports whats called multichannel mpeg audio. It supports up to 7.1 channels and is literally as good as Dolby Digital in quality. As TeeRex suggested, the hardware support is extremely limited. You pretty much have to have a Philips dvd player and your decoder has to have support for multichannel mpeg audio and even if both of these apply, there is still no guarantee it will work.
Doug57 if you have a Dolby Pro Logic decoder than you should be getting more than just the front speakers. If your decoder only supports Dolby Surround then you have to do a dolby surround downmix before you encode. The conversion guides explain how to do this.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
