I've tried to track down a problem i've had for a while now and nothing seems to give. I've looked on numerous forums and no info or any similar problems have cropped up like mine.
The problem is i can play 75% of my divx movies in WMP 7.0 and they look fine but the other 25% they look horrible even thou it's DivX. I can open the movie up in DivX Player 2.0 and it looks wonderful.. the way it's supposed to but then when i use WMP it's nasty. I'm not sure why it only does this on certain movies i've tried to get specifics on the avi files but nothing seems out of whack on them. I'm at a loss to be honest and i've tried to goto my video compression codecs and remove some of them but they never actually remove if i go back and check them out.. strange.
I'm using win2000 and have the latest nimo codec (no g400 stuff installed) and 5.0.2 divx codec. My other 3 machines play 100% of the avi files and they look great but my main machine just isn't having it.
Codecs Installed via Video Codec Properties page:
Cinepak Codec by Radius Inc
Divx Mpeg 4 (fast motion)
Divx Mpeg 4 (slow motion) (both of these i removed manually but they still show up.)
Divx 5.0 Pro Codec
Divx 4.12
Huffyuv Lossless
Indeo codec by intel
Indeo video 5.10
MS RLE Codec
MS Video 1
msh261.drv
msh263.drv
msyuv.dll
Xvid Mpeg 4 Video Codec
If anyone has heard of a similar problem or need more specific info in order to help me out i'll be glad to supply it.
Thanks in advance for anyone who responds.
!!!3D playback with VLC, MPC, WMP, HELP!!!!!
By NateDizzle in forum Software PlayingReplies: 6Last Post: 17th Feb 2012, 20:31 -
Sluggish WMP playback
By frogger012 in forum Software PlayingReplies: 2Last Post: 18th Jan 2010, 14:48 -
H264 Playback Problems in WMP 11
By seasonsofwither in forum Software PlayingReplies: 3Last Post: 21st Dec 2009, 23:49 -
wMP 11 Playback
By lowfell in forum Software PlayingReplies: 5Last Post: 6th Jun 2008, 10:52 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19
