I've been looking for a good DVD player that has progressive scan with dvd, cd, mp3, vcd, svcd, cd-r/rw support. The JVC XV-S500BK was pretty much the only one I could find, so I came here and all of the reviews looked very favorable on it. So I decided to run down to Best buy today and pick one up. After hooking up everything I popped in a dvd and it started playing, then i tried an mp3 disk. Again this worked like a charm with long names and all. So I decided to try a vcd I burned to a Memorex cd-rw. I popped the disk in and after a few seconds it says error and spit the disk back out. I also tried buring it to a cd-r disk also with no success. Then I tried these disks in my older Sony DVP-S530D but couldn't get them to play. I'm using a Sony CRX185E1 burner and Fireburner. I have also tried Nero. Is there a problem with this burner or something ? I can't figure out whats wrong.Any help would be appreciated!
The VCD/SVCD files you are trying to play back might not be standard compliant. Make sure the settings used on the VCD/SVCD comply with standard specs. If your player is supposed to play XVCD/XSVCD, then there may be a problem elsewhere.
Visit my webpage at:
http://leech.at/e-z-e -
i use vcdeasy to make sure the .mpg file i'm burning is compliant for either VCD or SVCD. nero will complain as well when using the nero VCD or SVCD templates, but vcdeasy is a lot more strict and creates better complaint cds that will play on most dvd players than nero.
Ok, guys thanks for the help. After messing around with Fireburner I got it to work in that.
Can you tell me how you fixed the problem, 'cause I have the same one!
Thanks!
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:40 -
how to play seamless loop svcd's
By markwest in forum Authoring (VCD/SVCD)Replies: 8Last Post: 11th Aug 2007, 15:06
