Is there any way to know the size of a file after it has been encoded by tmpgenc? Often times after i encode a movie its bigger or smaller that id like it to be and id have to encode it again. I know that there are bitrate calcs and others but im wondering if there is a feature in tmpgenc that will tell you the final file size. Any help is appreciated. Thanks
newbiexp
Have you used the wizard? The last screen will give u a pretty good estimate of the file size if you use CBR.
File Sizes
By rhodellf in forum Newbie / General discussionsReplies: 7Last Post: 18th Jun 2009, 13:51 -
Differing File sizes from same content
By wozmac in forum Video ConversionReplies: 5Last Post: 13th Mar 2008, 10:45 -
OGM vs MKV file sizes
By MasterRoshi in forum Newbie / General discussionsReplies: 5Last Post: 25th Jan 2008, 09:25 -
Different sizes reported for same file
By Richkut in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2007, 16:45
