  1. Just wanted to know if anybody has had trouble with ulead dvd picture show?? When I play it back in my apex the pictures look fine but the music has static after every frame advance. Is there a solution for this. I did call there tech. Ha what a joke!!!!!!!!!!
    Feb 2002
    Clearwater, FL USA
    If you are using an MP3 file for your music track this may be what is causing the clipping. I've had the exact same thing happen to me when making a simple slide show using Ulead VideoStudio, however, when I converted the MP3 to a WAV and used the WAV file for my music track the problem disappeared. Since then I simply won't use an MP3 file for background music on any of my projects, I only use WAV files and have not had any clipping problem since.
    Hope this will help.
    Evil flourishes when good men do nothing.
  3. I;ve used it and it plays fine on my Apex 1500. Maybe your TV is too close to your audio pickup & some RF from the TV is getting into the audio circuit causing sounds as the picture changes? Or is it more like a hiccup?
    I found a bug that if the song is less than the picture track then it goes into a random place on the song (won't go back to the beginning of the song) - I then make sure the audio is > the length of the set.
    Panasonic DMR-ES45VS, keep those discs a burnin'
  4. I also convert my MP3s back to WAV for DVD Pictureshow - makes a difference somehow.
  5. Ok I will try and see how it goes. I'll get back as soon as I have an answer. Thanks for the help.....
