Hello all,
Does anyone know if there is a reg. hack to adjust the captured avi file size? Ok, when the 2g limit is reached,
and the capturing (in short) is, say, 3gigs, the DC10's
final captured avi's will of ben split to 2 files
2g and 1g. I was wondering if one could set the limit to
something lower. What I want to do is copy my captured
avi's and archive them to cd-r at 560mb or 600mb in size.
This way I don't have to split them with an avi cutter (which never really work well) and it would be so much easier and easier to burn them on cd-r, for late re-encoding projects - say, you found the ultimate encoder and wish you
had the old captured avi's. know what I mean. I have a
bunch of avi's that I captured, but I really don't want to
loose them just yet. I want to burn them at 600mb intervals to cd-r's.
Can this be done, or am I just wishing - (ok, just wishing?)
Thanks all.
Results 1 to 1 of 1
Reg free BD players?????
By cinemareplicas.com in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Nov 2009, 06:40 -
SVCD2DVD Reg -3 times
By dr4son in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Oct 2009, 17:45 -
By duzmor in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Sep 2009, 04:59 -
reg converting nd burning dvds....
By liddu in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2007, 04:50 -
reg the application to use
By liddu in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2007, 03:31
