i read that to solve jerkiness, you can set the VBV buffer to 112 or 0 (automatic) on Kwag's template.
was wondering what kinds of effect would this have on the filesize/stability of the video?
thanks
Cheers~
JCPicache -
ahh, why don't you just try it?
you don't HAVE to encode a whole movie. . . just a 1 minute section, then
burn it and play it on your dvd player. Too many dvd players out their,
and too many different settings per person's taste, etc. to give you an
deffinate type of answer. You just have ta try it yourself and see if it
affects your dvd playing. Only you can know this for sure.
later
-vhelp
for lastest sample(s) of VCD clips, see VHELPs VCD Samples -
Best is setting VBV to 224 in Tmpeg (which is mpeg2 maximum), second is to use the automatic option (0 ).
But some players canīt handle the 0-setting ...
regards
mb1
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 03:45 -
YouTube Buffer Speed
By gooberguy in forum ComputerReplies: 4Last Post: 25th Feb 2010, 21:12 -
Buffer Device question:
By butt_crack in forum DVD RippingReplies: 1Last Post: 5th Feb 2010, 11:35 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 09:04 -
chunktab buffer too small?
By 820am in forum ffmpegX general discussionReplies: 1Last Post: 21st Dec 2007, 12:57
