hi, i have a problem with my Mpeg movie. I was downloading a file and i stopped the transfer with only 24 seconds in the movie. I then resumed the transfer and got at least 37 min of the movie. WHen i play the file, the scroll that skips to other parts of the movie only goes up to 24 seconds, once the scroll reaches close the end, it stops and the movie keeps playin, and i am not able to skip to parts after 24 seconds, is there a way to fix the mpeg ?? thanks for your help.
try demultiplexing it and then re-multiplexing it using a different file name.
TMPGEnc does this very fast and very well...
Big_Jit
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
