Hi people, I'm a newbie here and I need some opinions:
I want to capture a video and then convert it to DivX. What is the best way to do that?
Should I capture it already as DivX? Or as mpeg and then convert it to DivX?
What software should I use to capture and which one should I use to convert?
Is Adobe Premiere a good sofware to do those things?
Thank you!!
You capture to the best of your ability, if that happens to be mpeg with no frame loss, then that is the best option.
However if you can capture to the final format without problems, then there would be no conversion afterwards. I capture to DivX Mpeg4-V3, and its very good, these are for sharing.
If I capture to VCD mpeg, and there are problems, it is not as easy to fix problems in Mpegs than it is in AVI.
So experiment..., try all the codec's some work better than others on different systems.
F4F capturing/converting
By konverter in forum Video Streaming DownloadingReplies: 348Last Post: 22nd Nov 2017, 03:07 -
Getting the most out of 30 fps when capturing/converting
By CursedLemon in forum Video ConversionReplies: 4Last Post: 26th Apr 2012, 09:11 -
Newbie question - capturing and converting from DV
By zaspa in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2011, 15:56 -
Capturing and Converting To DVD Problem
By Mike1956 in forum Video ConversionReplies: 2Last Post: 18th Jan 2010, 16:44 -
Capturing and Editing/Converting
By eighteesix in forum MacReplies: 3Last Post: 26th Mar 2009, 11:20
