anyone know?
Hi mate
there is very basic editing of real media files in real producer. You can extract clips from a file , then merge them together. It can however be time consuming . Don't expect professional editing type applications for this format.
cheers
scouse -
You might convert (or import if possible) these into a real video editor, edit, then reencode to rm or another format. If faced with this task I would convert to AVI in a lossless format like huffyuv, edit with MediaSTudio Pro, then export to real or whatever. If you use a lower end video editor like Pinnacle Studio 7 you might have to pick a mainstream codec like Indeo but the process is the same and Studio outputs to popular formats like Real & Quicktime (but the mpeg encoding is rather poor - export to AVI then use TMPGenc for MPEGs).
Panasonic DMR-ES45VS, keep those discs a burnin' -
oooo
Thanx. I was trying to convert my RM file into a .avi file, but its took me a hour to get bout 6 mins of film done.
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
How I can cut TS files ?
By Torresinho in forum EditingReplies: 1Last Post: 14th Feb 2010, 15:15 -
converting .rm/ram files
By schnaarf in forum ffmpegX general discussionReplies: 4Last Post: 15th Mar 2009, 15:19 -
Can't Convert RAM files to MP3 with ffmpegx
By bowjest in forum ffmpegX general discussionReplies: 8Last Post: 23rd Dec 2008, 07:59 -
RAM .vro files to usable format?
By nelsh in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 19:05
