  1. Silly question-
    Is there a way to get VDub to remember the TV Tuner's channel setting? The default appears to be 4 and my system uses 3. Everytime I load Vdub I have to go in and change it back to 3. Can't find a setting to get it to stick.
    Thanks in advance,
    Drak
  2. Chris S ChrisX's Avatar
    Jan 2002
    Some dude from Sydney
    VirtualDub doesn't remember the TV tuner's channel. It only links to the TV card, that is all it does. VirtualDub has no tuner, so therefore you set the VirtualDub to capture from the TV card or video card. You have to set the default channel at the source, the TV card tuner to fix the channel.
