I guess I would consider myself a Newbie since I haven't been able to get my own CDR VCD to work yet. I have a Daewoo 2000 DVD player and I've run CDR VCD's that have been burned on other people's machines, and have burned CDRW VCD's on my own machine, but I cannot get a CDR VCD to play on my DVD player that I have burned myself.
I have tried MANY different programs to burn as well. Nero, EZ-CD Creator, VCD easy, fireburner, etc, etc, but none will play on my DVD player. Anyone have any suggestions.
This is my first post.
According to your post you tried CD-RW dics from others and CD-R dics that you burned. Try burning to a CD-RW and see if it works then.
tgpo - I actually tried that also. I burned a Memorex CDRW and it worked fine on my DVD player. As I mentioned also, I borrowed a VCD from a friend and my DVD played that too, so I know it plays both CDR and CDRW. The only problem is that I can ONLY play CDRW's if I try to burn using my machine. I've also tried 4 different brands of CDR's and none of them will work when I burn it. In addition, I've tried 2 different burners. A sony burner and a Ricoh. Neither are top of the line, but both SHOULD work. I'm stumped at this point. (I've burned lots of coasters with many differnet software packages)..
Thanks for the thought. and thanks to anyone else that has ideas as well. I'm open to ALL suggestions at this point. -
Will a CD you burn play on your friends DVD Player?
Edhttp://www.paypalwarning.com/
Does it rain here?......Yes it does......Frequently
from the Murky Island
ED... 7:40:49 am
8 JUN 2002 -
yes MY dvd player plays some VCD's but doesnt play others even though its not supposed to read CD-R's. Strange I know but it happens.
I haven't tried yet, but planned on trying to run the CDR VCD's I burned, on a friends DVD player to see if THAT works. That's the only other step I could think of to try. Beyond that I'm completely at a loss.
Thanks -
To add to my earlier questions and comments, I have found that only one brand of CDR works on my Daewoo model. Believe it or not it's Office Depot. Does anyone know what brand of CDR's work best with earlier Daewoo's like the 2000.
I've tried Imation, Memorex, and a couple others. The Office Depot CDR and Memorex CDRW are the only ones that have worked so far, although the Office Depot I didn't burn myself.
Thanks again everyone.
Daewoo DF4100P
By hillneerg in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Feb 2011, 11:06 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Hack the Daewoo DS-K965
By sonquilombo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Jan 2009, 18:08 -
DVD Daewoo DS-K960U
By TonitoDJ in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th Oct 2008, 09:08 -
help ripping dvd too play in a sv 2000
By whomeno in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2008, 11:08
