I want to be able to back up my son's VHS tapes and was wondering if the Dazzle DVC II and Sima SCC Pro Video Color Corrector / Clarifier / Stabilizer Enhancer would be all that I needed. I have read a lot of posts and was wondering if this would be a good choice. Also, sould a 40 gig hard drive be enough?
Results 1 to 10 of 10
Absolutley - should work very well.
If your sons's tapes are in good condition you should send me the Sima SCC Pro Video Color Corrector / Clarifier / Stabilizer Enhancer
In all seriousness you only need a authoring package like Nero or VCD Easy.
If you want some tips with the Dazzle let me know! -
I was thinking about the stabelizer for the macro vision or will the dazzle take care of that on it's own?
No the dazzle has no macrovision support - It ignores it completely - well let me say mine does (I have the Australian version that supports PAL/NTSC/Secam , I don't know if there are other versions)
I have copied everything even DVD's with it.
But if you have the budget then go for the stabelizer to clean up the video, after all garbage in, garbage out -
Perhaps you could give me some advice, since I'm considering buying the dazzle DVC II...
How good is the quality when copying DVD's and VHS?
If you plug a TV into the dazzle can you play Mpeg and DivX movies on the PC but watch them on the TV?
Thanks for your help... -
Quality is quite good especially when you factor in not having to wait for any encoding to finish
The quality can't match a 2-pass VBR encoding with either TMPGEnc or CCE - naturally no hardware encoder even could - but still does a good job
VCD - not bad but I would only show junk with and nothing good, the resize is poorly done, better to cap in SVCD or DVD and re-encode down to VCD
SVCD - quite good, I use this for most things nowdays - It's easy, looks good and can be dumped striaght to Nero and played on my DVD player(s)
DVD - looks just like the original in most cases, the only time this falls down again is when there is a huge amount of movement on the screen such as anime or stuff like that.
You can playback MPEG clips (not Divx) to a TV but it's a software decoder, I bought a videologic cheapo knockoff of a Hollywood Plus card (use hollywood plus drivers! )for about AU$90 and use that to play my MPEG's back to TV
The card comes with moviestar as the main capture program - it's really bad and bloatware in my opinion - I use only the capture part of it
Moviestar use 24.5 MB of RAM and 14.8MB of swap space and a chunk of drawing and control resources - before I switched to XP I had a few resource crashes in Win98. Things are much better now with XP
Moviestar comes with a simple NLE editor (crap), picture cap (again crap) and sound editor (still crap, are you seeing a pattern here? ). I rarely use it now, I prefer using TWNH it's a reverse designed Dazzle capture program that uses MUCH less resources than Moviestar.
You can only use Moviestar or TWNH to cap nothing else will work.
Anyway if you want any more info please mail me - If I can help great! -
I want to do the same thing -- archive some VHS tapes. I have a Canon ZR45MC MiniDV camcorder that does GREAT VHS captures, except when the VHS tape has Macrovision encodeing. The ZR45MC halts all pass-thru.
I am hoping that a device like the Sima SCC Pro could be put inbetween the VCR and the camcorder.
Any thoughts?
Note: I'm not proposing to do anything illegal. I just want to preserve the investment I made in a collection of several degrading VHS tapes that aren't available on DVD. -
Well expanding on what I said here
You can find TWNH here:- http://stop.at/TWNH
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
Backup copy of Protected VHS tape
By mcassidy in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2009, 12:05 -
Panasonic DMREZ37V VHS Backup
By mrfixx in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Sep 2007, 13:07
