Hi I have ripped a movie, used DVD2AVI, then encoded with TMPEGEnc and ended up with a MPEG file. If I want to take that file and burn it onto a DVD-R so I can use in my DVD player which program should I use. I have Nero but when I pick DVD Video it has 2 files Audio TS and Video TS----it wont let me put the MPEG file into the VIDEO TS. Do I leave it out or should I use another program.
i believe you are going to burn it onto a cd-rw as a video cd, that way your dvd player should be able too play it
Need more info---did you burn it as an MPEG-2 in TMPG? Further, are you *sure* it's DVD-compliant?
no, burn it as mpg1, mpeg2 is svcd. unless you know for sure yours will play svcd's, you will be wasting your time, but if your dvd will play vcd's then yes it will work if burned as mpg1. thats how i do it and i have not had any problems yet
Ok this is more of a question than a reply. I just tried to burn a Movie with Nero and it worked fine but when I tried to play it in my DVD player it didn't work. I checked the manual of my DVD player and it says that it won't play CD-R's but it says it plays Video CD's. Currently I am using Memorex CD-R 700MB 80Min...could that be the problem or are there better or different CD's I should be buying to burn?
P.S. the DVD player I have is a Sony DVP-S360
Please help!
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
