I have a Norton Ghost floppy and some 2 GB .gho files. Biggest file is 2,124,414,976 (1.97 GB).
Can I create a bootable DVD-ROM with Nero, using the Ghost floppy and the .gho files?
What's the partition size limitation of the OS?
The total disc size would be much less than 4 MB and like I said the largest file is under 2 GB.
Results 1 to 10 of 10
Would this method work? Link!
Oh, I should mention that I only have an internal DVD-ROM drive as the boot ROM drive.
My CD-RW and DVD-R burners are both external Firewire. -
Haven't tried it yet. I've been authoring slide-show picture DVDs for my family. I'll try to get to it this week.Originally Posted by Kennyshin
Greg, my DVD-ROM is the first in the bootlist after the floppy, so that shouldn't be a problem. -
Eug....not sure if it is the same as cd drives, but I know that to boot from a cd drive the cd drive itself must be bootable....is your dvd rom drive?....t
Hi everyone - I thougth I'd waken this thread up as it's similar to the info I need to know.
Before going out and purchasing a DVD burner and DVD-ROM drives for rather a lot of PC's
Can you make bootable DVD disks?
If Yes does the majority of PC's that have a DVD reader allow booting from that type of disk?
If Yes I assume the disk is written in DVD-ROM format.If not please advise.
If the answers to the above are yes will a pioneer A04/104 do the biz for me.
Thanks in Advance
Bullfrog -
On my (not at all new) motherboard, like most others, the BIOS setup allows the user to specify which devices and in which order the BIOS will go through them at power-up and try to boot. I sometimes boot from my CD/DVD drive, using the XP install CD (OEM version).
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thankyou
I'm aware you can boot CD's we use them for machine recovery. The fact you can boot from them in a DVD drive is promising.
The basic question still exists can you make bootable DVD's?
Bullfrog -
Hi Peoples!
I've got an Pioneer A03, and i will get an A04 next weeks.
I've found 2 Software Packages, who could write bootable DVD.
1. Nero
2. Instant CD/DVD
i've tested both, but i couldn't boot from the DVD's
i've burned 6 dvd's in different constellations, from Floppy images, from Floppy Drives, from Win98 Bootdisk's and from a Norton Ghost 7.5 Bootdisk.
When anybody burned them succesfull, contact me pease!
Corelianer
Sony DVD bootable one one drive but not another
By perfection in forum DVD & Blu-ray WritersReplies: 7Last Post: 20th Jun 2011, 13:59 -
dvd burning error when make a bootable dvd image
By junian116 in forum Authoring (DVD)Replies: 1Last Post: 5th Apr 2011, 04:58 -
how to make windows 7 dvd bootable
By mysts in forum ComputerReplies: 8Last Post: 16th Jul 2009, 22:43 -
bootable vista dvd/cd
By romanstopme in forum ComputerReplies: 3Last Post: 18th Feb 2009, 05:33 -
Converting 2 avi clips to bootable DVD?
By apfable2 in forum Authoring (DVD)Replies: 6Last Post: 15th Feb 2008, 13:46
