  1. Hi I have ripped a movie, used DVD2AVI, then encoded with TMPEGEnc and ended up with a MPEG file. If I want to take that file and burn it onto a DVD-R so I can use in my DVD player which program should I use. I have Nero but when I pick DVD Video it has 2 files Audio TS and Video TS----it wont let me put the MPEG file into the VIDEO TS. Do I leave it out or should I use another program.
  2. You need a DVD authoring program such as DvdIt, DVD movie factory, DVD complete or one of many others. You the "author" the DVD (add menus etc) and the proggy will create all the necessary files ready for burning or even burn directly to DVD-r for you.
    You normally get a simple authoring package with your DVD-R (or +rw) drive)
