So I guess one of the TV tuner cards.
Need one that allows high res capturein win98se and win2k.
Not itntersted in capping in mpeg1/2 via software (or hardware for that matter)
Its looking like one of the wintv go cards so far.
TIA
Trik
I have had pretty good success with the ATI TV Wonder card (not the VE or USB version). It is about $50 at best buy/circuit city. The only problem that I see is that it only captures 240 of the 480 lines of an NTSC system.
I did download a program "IUVCR" that does allow you to capture at 480x480 for SVCD burning (and any other resolution for that matter). My "success" with this card may not be the norm as I have heard a lot of people upset with the support, driver installation, etc. Actually I have heard a lot of people complain about all different types of cards. The ATI drivers that came with my card are pretty good (again can't capture 240 lines needed for your TV) and I am in one of those "almost perfect" arenas when I use TMPGenc to convert my AVI (using huffy codec) and matching up against the original source. I cannot get virtual dub to work on my machine, but that may be just me.
Hope this helps
Advice on capture card pci express or usb, for windows 7, umcpmpressed avi
By victoriabears in forum Capturing and VCRReplies: 12Last Post: 1st Aug 2010, 13:39 -
Cap Card Editing Issue?
By Evas1on in forum Capturing and VCRReplies: 7Last Post: 7th Jan 2010, 11:25 -
Suggestions On Buying Cap Card
By x420x Lovin in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 02:14 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 11:58 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
