  1. Hey guys new to capturing need a little help,
    i have a aver tv card and i use the aver software which came with the card.
    it allows me to record straight onto my hard drive in either mpeg 1 or 2 format.
    mpeg 2, 352 x 288
    mpeg 1, 352 x 88.
    i have tried to capture a video i have with rubbish results,
    when i capture it to the hard drive it looks great, but when i tranfer it to
    vcd it looks and sounds crap.
    i have also tried the same in mpeg 2 with the same kind of results.
    i have also rigged the pc upto the digital tv, and again it looks great on the pc but when i copy it to vcd it looks preaty bad.
    i have also tried to take the mpeg i have captured and re-encode it
    with tmpge it looks alittle better but not much,
    i have also tried to use virtualdub, but it does not reconise the capture card.
    what im trying to find out is what im doing wrong.
    its it a crap capture card, am i using the wrong software, should i stop capturing straight to mpeg format? i need all the advice i can get here,
    my pc has a 20 gig harddrive, and is a 500mhz.
    i dont know what else i can tell you,
    please help
    Dec 2001
    Over There -------->
    With the AvetTV software you can try a custom format at a higher bitrate.
    Then use TmpegEnc to re-encode it.
    500 mhz is pretty slow for direct to mpeg via software though.
    You might have better luck using virtual dub and capturing in divx or MS mpeg4 at a bitrate as high as you can @ 320x24 then re-encoding it with tmpeg to vcd or svcd standard.
    You could also try PowerVCR to cap directly to mpeg 1/2
    This thread has some pretty good guidelines: http://www.vcdhelp.com/forum/viewtopic.php?t=88306
