i want to use tmpge to encode svcd. when i get to the section in the wizard where im suppose to put in the type of cd (80min) and the percentage of disk space(100%) ...i get a very low bitrate 570. im only trying to encode 67min of video and when i use the vcdhelp bitrate calculater ...for those specifications the bitrate the comes out is 1391...of course when i put 1391 in the tmpge it tells me that its not going to fit on one cd (it comes out to 203% - which is basically 2 CDs for 67min)
please help....
here is some more info:the source file is divx inwhich the 67min have a file size of 750mb (this is usally twice the usual size for a movie in divx but for some reason it was encoded as such- i dont think this fact should change the output but i thought ill just through it in here in case it does)
thanks guys
Well then dont use wizard/ According to FitCD your bitrate should be around the 1400-1450 mark, so use that
Mpg : Mpeg video size and bitrate calculation
By Bonie81 in forum ProgrammingReplies: 2Last Post: 21st Jun 2011, 23:38 -
Need some info on bitrate calculation
By heman28 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 19:18 -
video bitrate calculation
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 22:30 -
DTS nightmare goes on
By vertical in forum Newbie / General discussionsReplies: 16Last Post: 2nd Nov 2007, 11:40 -
Newbie needs bitrate calculation advice to convert my 1st PAL to NTSC
By queen_anne in forum Video ConversionReplies: 35Last Post: 20th May 2007, 22:48
