I guess the only way is to install this bad boy and give it a trywhen I find some time.
Back to DVD media, did anyone try the Optodisc DVD-Rs at shop4tech.com? 10pack for 16.99
http://www.shop4tech.com/cgi-bin/shop/shop.cgi?action=specs&&item=1029348639&&choice=C...VD-R%20Branded
It has some good reviews at newegg.com
http://www.newegg.com/app/ViewProduct.asp?submit=manufactory&catalog=146&manufactory=1...tby=14&order=1
Results 91 to 95 of 95
The problem is the APEX player drive. I had the same exact problem with the sampo player I have. The meritlines played great in my sony (which is 4 years old), my rca and my friend's panasonic. The truth is, the drives on these cheap dvd players such as apex, are not that great. Take it from me, I have been testing these a long time. My sampo claims to play dvdrw but doesn't. It won't even see the damn disc, even a tdk!
You know, it's odd that you say that, because I've also read that the A03 dosn't have burn proof.
And yet, EVERY program I use to burn DVD's with says "Burn proof enabled".I don't have a bad attitude...
Life has a bad attitude! -
Both the Pioneer A04/104 and the Panasonic LF-D321/LF-D311 have buffer underrun protection for DVD-R. (The Panasonic doesn't record to CD-R at all so obviously any spec'd buffer underrun protection for the Panasonic has to be for DVD-R.)
Just want to concur on what you've found. Exact same problem here. Tried playing them on Apex AD-1200 and Apex AD-5131. Also tried to play them on a generic brand DVD reader from another PC. Same shutter near the end of the disk. Ick!! Has to use those DVD-Rs for project less than 3GB. Sometimes even less than 2.5GB.Originally Posted by flaystus
VSO Media Player - report - doesn't play anything
By Jeremiah58 in forum Software PlayingReplies: 1Last Post: 19th Aug 2011, 04:39 -
Transfer of files from PC to media player storage - Which brand/model?
By holmerz in forum Media Center PC / MediaCentersReplies: 2Last Post: 23rd Sep 2010, 08:57 -
DVD on MCE 2002
By prabha in forum Software PlayingReplies: 0Last Post: 12th Oct 2008, 09:54 -
LiteOn LVD-2002 DivX/MPEG-4/DVD Player
By Roundabout in forum DVD & Blu-ray PlayersReplies: 448Last Post: 25th May 2008, 05:18 -
Best printable media? (Any 100% working brand?)
By Espen in forum MediaReplies: 14Last Post: 24th Nov 2007, 00:09
