I have a C drive with win98 in fat 32 on a 20Gb HD. I also have a 40Gb HD as a second IDE master. Is it possible to format the D drive in NTSF to install NT workstation? I'm in fdisk right now (D drive)...
and partition is done but it's not formatted yet...
Can anyone help?
Thnx in advance.![]()
"Resistance is futile"
"You WILL be assimilated" -
an easy way is to go into setup when u first start ur computer
then go to a menu which will say somethin like advanced bios features
there you should select your secondary boot device as Hdd-1 (it should originally b set as hdd-0)
N there u go, your secondary hdd will become the c: and your primary hdd will become d:, it will now boot from the secondary n u can install NT on there the way u would ne operatin system.
wen ur don installing, u just swap back from hdd-1 to hdd-0
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Question about portable drives, FAT32 and NTSF
By jtrinc in forum Portable VideoReplies: 6Last Post: 24th Nov 2008, 21:24 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
