im trying to split a 1.3 gig mpeg video into two files with tmpgenc. when i use the merge and cut option under mpeg tools i select the begining of the movie as the start frame and i select a point approximatly 1 hour into the movie as the end point( its actually 01:00:15). i saved the file as a different name and picked run. tmpgenc does the cut but it only makes a file that is 51 megs and about 5 min long. i cant get it to do any more that that.
what tmpgenc says when i hit run
outputting window
producing video stream 310.31 seconds (where it stops)
producing audio stream 310.33 seconds (where it stops)
multiplexing
then the file it gives me is about 51 megs
what am i doing wrong
TMPGEnc usually completes this task with no problems, provided the mpeg file has no problems. If there are junk frames in the mpeg file, this will cause TMPGEnc to stop encoding when it reaches those bad spots.
TMPGEnc Authoring Works 4 problems...
By gonzalo76 in forum Authoring (DVD)Replies: 7Last Post: 12th Oct 2010, 02:59 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 07:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 12:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 17:47
